saturable core modelling in PSpice
Discussion in 'Electrical Engineering' started by Adam M, Dec 2, 2003.
  1. Adam M
    Adam M Guest
    Hi folks,
    I'm trying to create a model of a practical 3-winding transformer - by using
    an ideal transformer and adding discrete components to model the losses etc.
    I want to create a saturable-core inductor to place accross the terminals of
    the primary of the ideal transformer to model the B-H curve.
    I've read a bit about how to do this, but everything seems to be aimed at
    "SPICE 3", and I'm using PSpice in windows. (I'm a novice!)
    What should I do? Does anyone know of downloadable saturable-core inductor
    models? Or somewhere else I should go for a tutorial on this?
    Thanks in advance!
    Adam.
  2. Hello Adam
    If you are a novice, you are taking on a real challenge. I have done some
    modelling of iron core devices using Spice 3, and I did not think PSpice is
    that different. One approach that I have used successfully for some purposes
    is to model the hysteresis loop as two inductors and to switch between the
    unsaturated inductance, and the saturated inductance using switches
    controlled from a circuit calculating the value of the flux. Applying this to
    a 3 winding transformer would be quite interesting.
    John
