SANYO LCD projector - repair question
  • Thread starter Servis za elektroniku ?
  • Start date
S
I have recently purchased on Ebay Sanyo PLC-SU10N (Boxlite CP-10t,
Eiki LC-NB1) LCD projector. Owner said it has burned lamp only.
I have replaced the lamp. Unfortuantely projector doesn't work.
Projectors turns ON. For about 10 sec's lamp lights and then light
goes off. I have checked what is going on trought the lens and I can
see the SANYO sign but it desapers when light from the lapm went off.
Tryied to check how long the SANYO sigh will stay on, with external
light source, and without lamp, and it desapears aproximately the same
moment when light from the lamp goes off - appx. 10 sec.
Any other indications on the controll panel apears to be normal.
Any idea what could be wrong ?
Jerry G.
Check the power supply performance, and also check that the fans are
working properly. Farther than this, you will have to get deep in to it
with the service manuals, and having the experience and tools to service
it.
If it is not something simple, you will most likely have to send it to
the Sanyo service centre to have it properly repaired. Most of their
servicing is done at the board exchange level, and then they do the
calibration of the boards that they change, if necessary.
Jerry G.
message Hi,
jakdedert
it with the service manuals, and having the experience and tools to
service it.
Is there an hours counter that you must reset on that particular model,
after changing lamps?
jak
There is a option to reset the counter, but I can't get into the manu
as it goes to stand by after 30 sec.
What I have noticed last night ... when the lamp starts, it lights for
30 sec. and the light is not very bright. Then, that is how it looks
like to me, there is a moment of short bright blink and at that moement
projector gets into stand by mode. Just curios if there is a something
like warm-up period for the lamp (30 sec) and after that the lamp
should get full power. If that is so, I should check the high voltage
power supply.
It would be very helpful if someone knows if the lamps in projectors
has some warm-up period when they are running on lower HV ??
