Sanyo ds27930 picture squashed
Discussion in 'Electronic Repair' started by [email protected], Jan 9, 2006.
  1. Guest
    My Sanyo ds27930 27" TV has a problem with video.The picture is
    sqeezed down to a stripe about 5 inches high.Black above and below.You
    can see snow and the menu words , but they are all on top of each
    other.I don't have the remote and when I try to get it on to the menu
    to switch it to "line in" , I can't see through the garbage .Poked
    around , checked for bad solder joints....and found noneAny help on my
    next direction is needed and appreciated.
    Thanks ,
    Alex.
  2. Guest
    Vertical circuit problem. Probably bad capacitors in the vertical
    output or solder connection problems to the ic. Check the capacitors
    with an ESR meter or jump them out to find the bad one.
