Sanyo DS25330
Discussion in 'Electronic Repair' started by DEBORAH ECK, May 7, 2004.
  1. DEBORAH ECK
    DEBORAH ECK Guest
    I have a Sanyo DS25300 that won't turn on. It will click on, then click
    back off (The relay). No power is being supplied to the Flyback (as far as
    I know). Since it was inexpencive, I replaced the Flyback, and still no
    luck Prior to this the Picture tube had thin green lines running across the
    tube, slightly at an angle but had a good picture (You only noticed the
    lines, when it was a dark picture). However, i did slightly notice it had
    slightly darkened in brightness about two weeks before it's death. Wife was
    watching the TV, and she said it just turned off. Now it don't do nothing
    (except the click of the relay). Am I correct on thinking that the Tube is
    gone?
    Thanks in advance, Rick
  2. Jerry G.
    Jerry G. Guest
    It sounds like the CRT may have died (may be going internally shorted), and
    the HOT may also be damaged. If this is the case there may be other damage
    as well. Usually when these parts go defective, there are other support
    components that also fail.
    All would have to be properly checked out to verify.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    gone?
  3. Ricky Eck
    Ricky Eck Guest
    Well, that was my idea. Will wait to see if anyone else has any other
    suggestions. I was just hoping that the fading picture was because the
    Flyback was going out. But it was the worst of the evils.
    BTW, what is the Definition HOT? What part of the TV does "HOT" refer to?
  4. Cyrus
    Cyrus Guest
    HOT = Horizontal Output Transistor
    Regards
    Cyrus
  5. Remove your Horizontal Output Transistor. Make sure it's good.
    Fire the set up and verify proper B+ voltage on the collector pad.
    Set may just be shutting down due faulty 125V B+ supply
    Jeff Stielau
    Shoreline Electronics Repair
    344 East Main Street
    Clinton,CT 06413
    (860)399-1861
    (860)664-3535 FAX
  6. Also..........your green retrace may have been just an adjustment issue ( G2
    or Green cutoff)
    Got access to a CRT tester?
    Jeff Stielau
    Clinton,CT 06413
    (860)399-1861
    (860)664-3535 FAX
  7. Ricky Eck
    Ricky Eck Guest
    Well, I decided to just NIX the unit. I don't have the equipment that I
    used to have about 10 years ago, when I worked on electronics. And I am not
    about to go out and buy it all over an 11 year old TV. I do have another
    Sanyo TV that has a bad tuner, that the one from this TV will work on the
    other. So I am going to part out the TV that Craped out on me, and fix the
    other one. Within one week, both Sanyo TV's went out on me. But the
    smaller one was because my wife kept beating on it to get it to work, and my
    Laziness to get up and fix it. Just it is hard to watch a little 19" from
    the Bedroom, when you are used to watching a 25". Just will have to break
    open the wallet, and get a new one...:) LOL
    Thanks for everyone's help
    Rick
