sansui 9090DB tuner dead
Anyone familiar with tuner problems on this model? The radio started
working intermittently but it hasn't come back on in a long time.
Typical Dolby switch problems, but other than that it is an amazing
sounding receiver. If someone could recommend a repair tech in the
Sacramento, CA area, it would be much appreciated.
Chris
D
David Farber
Chris
Hi Chris,
Do you have an antenna hooked up to it? Are both the AM and FM dead? Have
you turned off the FM muting? Do you hear static or is it completely silent?
The typical problem with these sets was the function switch burning out.
Good luck.
David Farber
David Farber's Service Center
L.A., CA
