SANGAMO Powermeter KYWP 3oooW 120 VAC
Discussion in 'Electronic Repair' started by noexpert, Feb 5, 2006.
  1. noexpert
    noexpert Guest
    Hello Group,
    got some interest in this powermeter made by SANGAMO.Seems to be for single
    phase 120 VAC.
    The below info was lifted off description.
    Can I ask for your input if this represents a correct explanation or ask for
    correction please or any other useful hints.
    Copied from Ebay:
    "At the far right side of the white dial a circuitdiagram can be found:Three
    independent in series loops @120VAC are input to cumulative record wattage
    to a maximum of 3000W total; you can use just one or two or three to the max
    of 3kW. In addition to these 3 loops( 6 big Terminals)two more loops(4
    smaller terminals)are also present. As far as I understand these can serve
    to remotely sense wattage. I never used those in the meter I have for myself
    but there are many web(news) groups to get help/info if need be. Trust this
    helps you and good bidding "
    http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=6033362916&ssPageName=ADME:L:LCA:CA:11
