Samsung Vertical
Discussion in 'Electronic Repair' started by Vince, Aug 14, 2007.
  1. Vince
    Vince Guest
    Hi.!
    Samsung MdlTX2756, vertical ic was shorted and burned out fusistor
    and a peaking coil, I replaced the ic fusistor and peaking coil, I tried
    the set and all I had is the bottom half of the screen, I don't have a
    drawing for the set so I thought I would see if someomne could give me an
    idea where to go next, I don't want to buy a schmatic unless I have to.
    any help would be apriciated.
    Thank you
    Vince
  2. AJ
    AJ Guest
    Check the associated caps and power supplies to the vertical ckt.
  3. Dani
    Dani Guest
    You MAY have a bad new IC, it happens! There are three zener diodes
    right by the vertical IC! Replace the 470 uf capacitor by the IC.
    Dani.
