Samsung TV TXE2745 (KCT52A)
Discussion in 'Electronic Repair' started by Searching, Apr 12, 2007.
  1. Searching
    Searching Guest
    TV was dead. Flashing front LED. Putting an extra load on the power
    supply (100 W light bulb from B+ to ground) caused the TV to power up.
    TV stayed on when the load was removed.
    Re-soldered most of the power supply circuit. LED no longer flashes.
    Stays on continuously, but TV no longer powers up. I get only 40 volts
    to the collector of the HOT. 14.5 volts line O.K. Tried another
    programmed EEPROM. No change. Everything I check, checks good. I'm
    stumpted. (I've checked for solder bridges).
  2. Guest
