Samsung Television Issue
Discussion in 'Troubleshooting and Repair' started by Newcomer, Jul 28, 2012.
  1. Newcomer
    Newcomer
    Jul 28, 2012
    Hi guys,
    I am having a problem with my Plasma TV and I am hoping I can get some assitance from you guys who know about this stuff. I have no problem trying to fix the television myself and I am certain that I can fix it I just need a little direction on what to look for or at. I have no real experience with electronics.
    I have a Samsung HPS5053X/XAA which is a 50" Plasma. The TV has started to have an issue where the screen will go black after it is on for 30-45 minutes. If I shut the TV off for 10 minutes and turn it back on then it will work fine for about another 30-45 minutes before going black again. When the screen goes black I can still hear the sound, I have tried pushing the menu button on the TV when the screen is black but it does not come up. I have read about bad capacitors but it seems that problem is linked more to a black screen on initial power on. The TV does seem to "prime" itself when I first turn it on, it changes from black to a very dark grey when I first turn it on and then the image comes up. It seems to me that something is getting hot and causing the image to go out??
    Lastly, I am sure this is not the first time this has been asked and I apologize if this has been covered and there is already a thread covering it. Thanks in advance.
  2. tukarrosa
    tukarrosa
    7
    Jun 25, 2012
    which colour has the light(ON button),when the screen goes black???surely they are bad capacitors(they look bumped compared to other capacitors). In short I think you should check if all the components are working well
  3. Newcomer
    Newcomer
    Jul 28, 2012
    The power button on the face of the tv at the bottom has a blue light around it which is illuminated when the tv is powered off. When I turn the tv on the blue light around the on button goes out and it stays out also when the tv goes black..........
  4. tukarrosa
    tukarrosa
    7
    Jun 25, 2012
    Have you checked the components on the circuit board of the switching power supply??
