Samsung S51A chassis TV fault
Discussion in 'Electronic Repair' started by Hannes Strydom, Mar 20, 2005.
  1. This set switches on briefly (less than 1 sec) with EHT, then off again and
    rapidly flashes red LED on front till switched of at mains. Replaced the
    video processor tda 8844, wich was 12 ohm to ground on pin 47.also replaced
    vertical ic tda7845 wich had a big hole in it! The set still has same
    symptom as before. Pin 50 on the tda 8844 is over-voltage protection and
    reads about 2.1 VDC when the fault is present but as i am without a diagam i
    dont know if this pin will go hi or low with overvoltage. HELP!
