Samsung LCD TV has a Faded Screen
Discussion in 'Troubleshooting and Repair' started by brownnk, Mar 11, 2015.
  1. brownnk
    brownnk
    4
    Mar 11, 2015
    When I turned on the TV it has everything the same and you can see the images on the screen but the color is faded, kind of like a haze across the whole screen. Anyone have any ideas before I take it apart to find the problem?
    Samsung 46"
    model #: LN46A530P1F A 1426112661231.jpg 1426112661231.jpg 1426112711609.jpg
  2. davenn
    davenn Moderator
    14,003
    2,025
    has some one been playing with the contrast, brightness and colour settings ??
    may be all the problem is :)
  3. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    It looks that way.. but I thought those 'tweaks' did not affect the settings menus.. ?
    Would be worth attempting to adjust to compensate anyway
  4. brownnk
    brownnk
    4
    Mar 11, 2015
    I played with the settings and nothing changed, if anything it made it slightly worse so i changed it back to the factory settings. Is there anything else you can think of?
  5. slanwar
    slanwar
    18
    Mar 5, 2015
    LCD, LED or Plasma? Plasma have the high voltage boards but if is a LCD/LED then the t-con may be bad, turn off the TV then press the mute button, 1, 8, 2, power, that will take you to the service mode, look for SVR (could be different menu, look for option if you can't see SVR), look for reset TV, after that unplug the tv from the wall and press the power button manually to discharge all the caps. Turn on after a few minutes and see if fixed the problem, if not then look for parts on ebay, t-con and main if that won't repair then you have a bad panel. The t-con must be exactly the same and normally they come with the panel but some stores sale the t-con only.
  6. Crenshtc
    Crenshtc
    Jun 1, 2019
    I'm having the same problem. I've replaced the main board and power board. Still having the same faded screen. I don't want to take the TV further apart but I don't see a T-com board in the TV. Do the new Samsung TVs have them?
