Samsung and AT&T U-Verse HDMI error?
K
Keith
All:
I just got off the phone with an AT&T U-Verse customer support person. I told her that an error
message was displayed on my TV in my back bedroom. It stated that it could not show the HDMI image
-- either U-Verse error H1005 or H1006. Even though the TV image showed fine underneath this
message.
She told me to get some component cables. What are they and does that mean that I cannot get
HDMI? BTW, I have a Samsung UN46B6000 in my back bedroom and a Samsung UN32B6000 in my
den. No such errors in the front den.
Keith Lee
S
Sofa Slug
All:
message.
Keith Lee
Although AT&T SHOULD be able to provide you with a problem free HDMI
connection, this may actually end up being a non-issue. Both HDMI and
Component inputs (not composite - that connection is for SD only) will
provide you with an HD picture. Component connections use 3 RCA cables,
color coded red-green-blue, and/or labeled Y-Pb-Pr.
HDMI is technically capable of a better picture than Component, but
because U-Verse (& other cable providers) typically deliver a compressed
picture, the source material may not be of high enough quality to where
HDMI will make a difference over Component. You may actually get a
higher quality picture via the Component connections, since the
Motorola/Cisco boxes apparently have a black level problem with HDMI.
Keith said:
All:
I told her that an error message was displayed on my TV in my back
bedroom. It stated that it could not show the HDMI image -- either
underneath this message.
mean that I cannot get HDMI? BTW, I have a Samsung UN46B6000 in my back
bedroom and a Samsung UN32B6000 in my den. No such errors in the front
den.
Keith Lee
It sounds like a handshake issue. That's when you are using
an hdmi cable and the tv has trouble connecting to the device
on the other end. I'll bet that's why the csr suggested using
component cables. Those carry video in hd, but not the audio.
You would need to use an audio cable with the component cables.
Do a search on your tv model and the uverse box. You may find
an easy solution for the problem.
Chip
R
RickMerrill
Keith said:
All:
message.
Keith Lee
HDMI cable carries a protocol between the two ends asserting that they are allowed to
talk to each other. It is conceivable that your tv or the cable box is unwilling
to show it! This may explain the advice from the support person.
As others have said,
Component cables have no such fol-de-ra and will transmit anything.
HDMI carries audio. Using Component cables you have to add audio, I think.
R
RickMerrill
LightByrd said:
It is conceivable :) that HDMI could deliver audio but you would still have to use
Component for the video. If the HDMI negotiation is rejected, do you get audio or nada?
K
Keith
Rick:
I usually get both but sometimes I also get the error message as well. I guess I will have to try different
HDMI cables to see it that is it. Any HDMI cables you would recommend? Thank you.
Keith Lee
Keith said:
Rick:
I guess I will have to try different HDMI cables to see it that is it.
Keith Lee
I doubt it's the cable. Have you done a search with your
television model number and the box that it is connected to?
Chip
D
David
wrote in message
Keith said:
Rick:
as well.
is it.
Keith Lee
When this happened to me once, I just reset the Uverse receiver
and all was well. Unplug it for 10 seconds, or press and hold the
power button for 5 seconds or so.
David
R
RickMerrill
David said:
wrote in message
When this happened to me once, I just reset the Uverse receiver and all
was well. Unplug it for 10 seconds, or press and hold the power button
David
I agree: it should not depend on the cable itself (all HDMI are really the same).
Unplugging and reseating can "fix" many things.
John McWilliams
Rick:
The ones that cost $110! :)
Seriously, anything on Amazon between a buck and ten bucks should do fine.
John McWilliams
Bah Humbug. Only $229 for a 2 meter HDMI cable? That's for
cheapskates. Real audiophiles buy nothing but the best and most
expensive.
<http://www.audioadvisor.com/prodinfo.asp?number=AQHDMIDIA&variation=2>
$1,394.75 for a 2 meter cable is more like it. It comes with a 72VDC
bias to do something to prevent dielectric absorption which allegedly
causes distortion. I like the "long-grain copper". I didn't know
copper has grain.
Copper?? Copper! Hah. It's gotta be long-grained silver or nothing.....
But I do like the price they're getting for mere copper.... must be over
$10,000 a pound...
