sampling through timer
Discussion in 'Electronic Design' started by jackbauer, May 16, 2007.
  1. jackbauer
    jackbauer Guest
    I'm using microC/OS on MSP430F1611 and have used semaphores in all of
    my SPI functions. Both the spi Tx and Rx use DMA.
    I have an 8 channel external ADC and I want to sample my channels at
    some rate using interrupt and Timer B. But I can't request a semaphore
    in ISR.... So I was wondering if anyone has a good idea of
    implementing a stable sample rate on an external ADC while using
    microC/OS tasks (I don't need to use timers if there is a more
    efficient method.)
    Thanks a lot.
  2. Tim Wescott
    Tim Wescott Guest
    The best way to do that is drive the ADC's start-conversion pin from the
    timer output pin, and drive an external interrupt from the ADC's
    end-of-conversion pin. That way you're controlling the sampling with a
    hardware timer.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. jackbauer
    jackbauer Guest
    I'm using ADS8345 which triggers a conversion whenever SPI receives
    one byte. So to sample a channel, I write a byte to SPI. So I'm not
    sure how to implement your method... Please advise
