Safewatch pro 2000
Discussion in 'Security Alarms' started by Dave S, Sep 30, 2008.
  1. Dave S
    Dave S Guest
    Dave S had written this in response to
    http://www.secure-gear.com/alt.security.alarms/5/-article-.htm :
    Goldendomers
    I have an ADT Safewatch pro 2000 installed when I built my house in 1999.
    I purchased the equipment. After 2 year I stopped the monitoring. I had
    two magnetic sensors go bad. I have been able to replace one and I would
    like to by-pass the second one for now.
    When I look at the keypad all zones are functioning except the one bad
    zone. When I by-pass that zone and set the alarm several areas when I
    test will not set the alarm off. I.e. when I open a window or door.
    Out of 8 Zones I would say 3 seem to be functioning properly.
    Any ideas what may be wrong??
    Delivered via http://www.secure-gear.co
    The Internet Knowledge Base for the security industr
    no-spam access to your favorite newsgroup -
    alt.security.alarms - 43410 messages and counting
  2. Crash Gordon
    Crash Gordon Guest
    I'd say you have a bunch of bad sensors...some open...some welded shut.
    You'll have to track down the bad ones and replace them.
  3. dave s
    dave s Guest
    dave s had written this in response to
    http://www.secure-gear.com/alt.security.alarms/5/Re-Safewatch-pro-2000-article47638-.htm
    Crash Gordon wrote:
    Crash,
    If the sensors are bad why dont the zones show as problems on the display?
    Crash,
    Thank you for the reply.
    I did have one sensor that was bad and that zone showed on the display as
    a problem. When I changed the sensor the zone cleared on the display but
    the alarm will still no go off if I open that door.
    All the other zones read O.K. That’s what is not making sense to me.
    If the problem was in the sensor wouldn’t show on the display as a
    problem?
    I did have an ADT rep come to the house and he wanted to install wireless
    units for the two sensors that were bad. He indicated to me that the rest
    of the system was fine.
    Delivered via http://www.secure-gear.com
    The Internet Knowledge Base for the security industry
    alt.security.alarms - 43435 messages and counting!
  4. Crash Gordon
    Crash Gordon Guest
    Lightning surges can weld a contact closed.
    A contact can get stuck from years of sitting there on a window that is
    never opened.
    Lots of things can cause a switch to not be seen.
    ADT loves to sell expensive fixes! You may just need 2 new 4$ switches
    instead of 80.00 each transmitters.
    **Crash Gordon**
  5. dave s
    dave s Guest
    http://www.secure-gear.com/alt.security.alarms/5/Re-Safewatch-pro-2000-article47641-.htm
    Crash Gordon wrote:
    Crash,
    Thank you. I changed out two sensors last night and the alram worked fine.
    alt.security.alarms - 43446 messages and counting!
  6. Crash Gordon
    Crash Gordon Guest
    Yea!
    You should check every door/window contact on a regular basis...turn the
    Chime on and with everything closed open/close every door/window and listen
    for the chime. I tell my clients to do it quarterly (when they get my
    quarterly bills from us).
    **Crash Gordon**
