Safe Use of Relay on 240v AC
Discussion in 'General Electronics Discussion' started by tmetford, Apr 14, 2011.
  1. tmetford
    tmetford
    16
    Apr 14, 2011
    Is it safe to use a relay that is designed for its coil to be operated by mains 240Vac to switch on/off a 12Vdc circuit?
    I have heard that the large potential difference between the coil and 12 volt terminals can induce arcing between them.
    The relay I've bought (Maplin - N13AW 5amp DPDT 240Vac) looks like its coil is well insulated from the 12V terminals but, having been told about the possibility of arcing, I just wanted to be sure.
    Thanks for your interest.
    Tim
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    They're made to take most of what the mains can throw at them, except lightning strikes. I'm sure one can find numbers on the isolation voltage rating.
    For the hobbyist the bigger safety issue is in the connections being made on/around the relay, rather than the relay in itself.
  3. tmetford
    tmetford
    16
    Apr 14, 2011
    That's great, thank you for your helpful advice and, of course, I shall take every care to make sure it's electrically safe as well.
    Kind regards
    Tim
  4. davenn
    davenn Moderator
    13,866
    1,958
    if you wanted something with better isolation you could use a SSL = Solid State Relay
