safe logic
Discussion in 'Electronic Design' started by [email protected], May 24, 2006.
  1. Guest
    Hello,
    I am looking for designs for inherent failsafe logic gates using
    transistors and relais, i.e. gates that fail safely if any component
    fails.
    An example for an AND would be two cascaded common emitter stages, the
    inputs applied to the collectors while the base of the first transistor
    is excited with a square wave. If any of the transistors fails the
    output will not be AC and therefore blocked by the transformer.
    Input A Input B
    | ------------. ,-->|- Output
    |------- | )|( A AND B
    ___ |/ | |/ === ===
    -|___|----| \---| GND GND
    square | |
    clock | |
    GND GND
    (created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
    Any article/book recommendations on this topic?
    Many thanks!
    Daniel
  2. Tim Shoppa
    Tim Shoppa Guest
    Anything in the railroad industry with the phrase "vital relay" will be
    of interest to you.
    Most of the literature in that particular subfield is more than 20 or
    30 years old.
    There are a couple of commercial adaptations to non-relay
    implementations in the past couple of decades that are somewhat
    documented by their manufacturers/patent owners. Look for phrases like
    "vital interlocking processor", "vital processor for interlocking",
    "Mircolok II", etc. Many of these adaptations involve good old
    physical vital relays on the outputs but replace many of the
    intermediate layers with microprocessors and very clever (often
    proprietary, although I think some patents are expring by now)
    algorithms.
    Tim.
