Is there an easy (read cheap) way to convert from SCART output to S=video input? TIA.
Thanks - When I finally found my Maplin catalogue, there was an adapter from SCART to S-VHS with 2 extra phono leads for L+R audio, presumably the PC S-VHS input card will extract the audio from the composite?
your mileage might vary but with my nvidia GFX card the svid output is just that - I had to run the audio from the sound card as well and then chucked everything into a little box with a scart plug on one side and svid & 2xPhone on the other (just looks like a big scart plug in the back of my telly)
The card's documentation claims it can feed output via S-video to a TV set as well as act as a capture card, but there are no RCA jacks for audio and one illustration shows a S-video to single RCA jack for composite video connection - so I wonder if the manufacturer has used a S-video connector more because its a good fit for the slot plate than strict adherence to the S-video standard.
Audio comes from your PC sounccard (or to in the case of a capture card). They use an S-video jack so S-video can be used, if desired. S-video is simply the Lumiance and Chromiance spearated. The card could simply gate the Chroma onto the Luma line, making it composite.
