Running Protel Autotrax under WinXP
Discussion in 'Electronic Design' started by Piglit, Sep 10, 2008.
  1. Piglit
    Piglit Guest
    I notice that if you boot 'Trax under XP, and it cannot find the
    design you were working on previously (ie you have deleted it), the
    program will hang. The only way of reviving it is to quit out and edit
    the config file to point to any valid PCB file. Anyone know any better
    way around this so that if it cannot find a valid .pcb file, it will
    open as a new (blank) file ?.
    cheers
    M
  2. Den
    Den Guest
    I dont know if this in any way relates to your problem but I had similar
    issues running 99SE under XP. The problem was related to file permissions
    set by our PITA company IT guys............ :)
