Running Palasm on WinXP
Discussion in 'Electronic Design' started by Fred, Apr 3, 2006.
  1. Fred
    Fred Guest
    Has anyone been able to get Palasm 4.5 to run on Win XP? I've heard it
    can be done, but so far it has proven to be beyond my abilities to get
    it going. Any advice would be appreciated.
  2. I run PALASM 4 version 1.5 from the command line. No problem at all. The
    only things I added were to set the environment variable PALASM to the
    directory where Palasm resides and the path should include the directory of
    the exe. So
    palasm=c:\palasm
    path= %path%;c:\palasm\exe
    petrus bitbyter
  3. Fred
    Fred Guest
    Dear Byter:
    Tried your advice... did not work. Error message is "Copyright (c) 1990
    Ergo Computing, Inc. os286: BIOS checksum does not match, please
    reconfigure". Any more ideas?
  4. My version is from 1991. Apparently you've got a slightly older version
    which includes some kind of copy protection. FAIK a 1.5 version has been
    around on the net for quite some time but may be vanished. If you can't find
    it maybe I can help but I need a correct e-mail address and you must realise
    it's almost 4MB compressed. May address should be valid after removing the
    spamtrap.
    petrus bitbyter
  5. Deefoo
    Deefoo Guest
    I've tried 1.5 on Win 2000 and it won't compile or simulate. It just stops
    without any warning and the log file is not generated :eek:( I've tried it in
    DOSBox 0.63 but that doesn't work either. I've only gotten it to work on
    real DOS.
    --DF
