Running circuits with USB to Parallel adapter
Discussion in 'General Electronics Discussion' started by lefam, Nov 18, 2010.
  1. lefam
    lefam
    43
    Nov 18, 2010
    Hello!
    Has someone figured out a way to program the parallel port using a USB/parallel adapter.
    I test my parallel port driven circuits using my old desktop computer. I would like to use my laptop, but it doesn't have a parallel port. So I would have to use an USB/parallel adapter. However, it is said that this adapters don't offer a way to directly configure the parallel port PINs.
    Has someone a way to run circuits using a USB/parallel adapter?
    Thanks.
  2. barathbushan
    barathbushan
    223
    Sep 26, 2009
    what do you mean by programming parallel port ??
    i think that such serial to parallel adapters are manufactured keeping the old parallel printer interface in mind . The new printers are all serially connected , eliminating the need for parallel ports
    Apart from connecting such printers , and few other such devices , i think it is difficult to find any other use for the parallel port adapters due to the design limitaions of such adapters .
  3. lefam
    lefam
    43
    Nov 18, 2010
    Thank you guys!
  4. eptheta
    eptheta
    188
    Dec 20, 2009
    Yeah I found an old one recently and tried to use it as a virtual parallel port. It has minimal connections so that it only serves as a printer cable and not the entire port....
    Yeah it stinks. If you are very adamant about having a parallel port on a comp with none, you can always buy one of these:
    This one
    This one
    Or This one
    2nd only if you have the spare room in your computer.
  5. (*steve*)
    25,419
    2,790
    And possibly only if your operating system allows access to the hardware.
    It certainly may be a problem with any software created before XP came out.
  6. lefam
    lefam
    43
    Nov 18, 2010
    thank you guys
