G
Geoff
or a build up of microwaves over a certain level?Peter Hucker said:Is it really true that turning on a microwave with nothing in it will break it?
Even more worrying - will it catch fire or explode?
Don't they have a safety cutout? Can't it sense the Klystron overheating,
concerned one of my pet parrots will switch it on! (Seriously, they doI have purchased a new microwave which has an easier to grab control. I'm
Mr. British for to let my family and me stay here... " Again, he'sThe Pakistani continues on his way and meets another passer-by. "Thank you
you for letting me come to your beautiful country." ... "I'm not British,He goes a little farther and meets another person and greets him "thank
Peter Hucker said:You mean they were lying?!?
well normally in order to cuase an explosion you have to have a combustable
material that burns very quickly,
the force comes from the fact that the burnt material wich is oxidesed takes
up a great deal more volume
and until it expands is under great pressure. in an empty oven there is no
combustables.
they always seem to try something to see if it blows up and if it doesnt
then they make sure it does, its often a caravan or microwave oven that gets
blown up.
magnetron and draw more power from it than it expects. I didn't agree orA colleague suggested that large metal objects might "short circuit" the
disagree, I know nothing about that sort of thing.
It cant 'draw' more power from it unless that power actualy goes somewhere,
however it can put the magnetron under more stress, the voltages and current
may be higher even though the power is actually less, ie they are out of
phase and hence arnt both high at the same time.
but theres actually not that much to a magnetron, theres a central cathode
wich is like a rod with a heater inside, and a circular anode around this
with slots in, all in a vacuum and also not surprisngly a strong magnet.
The power is picked up via a piece of wire inbetween one of the slots.
The anode is what gets hot due to current flowing and is attatched to a
quite large heatsink with great number of fins wich has a fan blowing on it.
theres not a great deal to go wrong, its simplicity is its strength, the
same basic design was used 60 years ago, it could lose the vacuum of course,
or the insulation could fail, or the heater could break, or the magnet could
lose its strength but most of the parts are designed to work at a high
temperature, its just metal and glass, its not like silicon wich self
destructs at 200'c.
The transformer does actually limit the current anyway.
Colin =^.^=
combustables.
PeterD said:WEll, almost right... (and your 'normally' does apply, so what you say
is true, but there's more! <bg>)
All you need is pressure, not a combustable substance.
In the case of the balls that 'exploded' were they to have a 'strong'
outter shell, and a high moisture content inside, the moisture could
easily convert to steam and build up pressure until the outer shell
failed--an explosion... It would not be difficult to build up a
hundred PSI of steam pressure, and that would result in a rather large
'bang'!
colin said:aha yes the Boiling liquid expanding vapour explosions didnt think of that
at the time,
but I did think enough to say normally lol,
bit like eggs that explode when you put them in a microwave without first
making a hole in them,
although its not all that exciting.
Colin =^.^=
waiting for me to chase after him. Came back the following day by himself,Peter Hucker said:They're cleverer than you think. One escaped, and flew from tree to tree
