How can I determine if a sensor or datalogger device's output can be correctly read by a PLC or RTU ? What are the compatibility specifications that I must observe to make sure that the sensor data will be read by the PLC/RTU ?
Pls refer to these devices for example:
The RTU is this:
http://www.gsm-m2m.com/EnproductShow.asp?ID=291#.VZIcv_mqpBc
then the sensor is this:
http://www.stevenswater.com/catalog/Product.aspx?SKU='90841'
Thank you !
The RTU is this:
Thank you !
