Karthik rajagopal
- May 9, 2016
- 257
- Joined
- May 9, 2016
- Messages
- 257
Hi all,
I was recently working with BQ32002 RTC IC from TI. Everything works fine except it lags by a seconds for every 24hrs. I had the same problem with ds1307 ic which had a lag of 5 to 6 seconds per day.
I am using an SMPS power supply to power my clock. So will the noise in the supply interfere with the oscillations of the tuning fork crystal?
I have done the following from my side:
1)Since the datasheet mentions an internal load capacitance, I didn't connect any external capacitors to the crystal. So, the oscillations must be pretty stable.
2) I have soldered them on a pcb instead of a general purpose board to prevent stray capacitance from affecting its oscillations.
What could be the possible reason for the lag and how to prevent that?
Thank in advance.
Thank in advance.
