RS485 question
Discussion in 'Electronic Design' started by joble, Aug 29, 2003.
  1. joble
    joble Guest
    Hello,
    I'm building a DMX-sender and receiver for distances up to 150 meters.
    DMX works with RS485 and this is able to do this, so no problem.
    I have a few questions:
    1) I want to use the SN75176 as an RS485 convertor. Are there better
    options?
    2) How should the topology of the transmitter look like? I think this
    can be made the most easy way. DMX-shield to ground, and DMX- and DMX+
    directly to the outputs of the RS485 driver. I'm i right or are there
    better ways to do this.
    3) Same question about the receiver. I see many manufacturers connect
    DMX ground to the logical ground on their PCB, but i do not believe
    this is the right way to do it. The data pins might be connected
    directly to the 75176 with a 220K resistor from the DMX+ to +5V and
    from the DMX- to ground. Again, is this ok??? Has anyone examples of
    an isolated receiver schematic?
    Thanks!
