rs485 code help/suggestions winavr gcc
Discussion in 'Microcontrollers, Programming and IoT' started by sherazi, Jul 7, 2010.
  1. sherazi
    sherazi
    91
    Mar 8, 2010
    hi friends!
    i wanted to implement rs485 communication b/w an avr and a pc.. the reason being distance up to 50 m b/w the two.. i am using the max485 ic, being the first time for such project wanted help and guidence.. i have a rs232-485 converter that i am going to use.
    as far as my thw knowledge i have upto now is that aprt from being half duplex, there is no other big difference in coding.
    i have the following code for initialization,
    Code:
    char ReceivedByte;
       UCSR0B |= (1 << RXEN0) | (1 << TXEN0);   // Turn on the transmission and reception circuitry
       UCSR0C |=  (1 << UCSZ00) | (1 << UCSZ01); // Use 8-bit character sizes
       UBRR0L = 0x0c; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
       UBRR0H = 00; // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
    well i am using 4800 baud rate because the other functions best suit 1mhz freq.
    for a test program that just listens for a byte and echos it back to pc
    Code:
    for (;;) // Loop forever
          //enable_rx;
         PORTD|=0x01;
    while ((UCSR0A & (1 << RXC0)) == 0) {}; // Do nothing until data have been recieved and is ready to be read from UDR
          ReceivedByte = UDR0; // Fetch the recieved byte value into the variable ByteReceived"
          //enable_tx
           PORTD&=0xFE
          while ((UCSR0A & (1 << UDRE0)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
          UDR0 = ReceivedByte; // Echo back the received byte back to the computer
    is this all ok, plz comment on code and give a better one if available....
    thanx in advance
    if someone can guide me to a tutorial on hyper terminal that would be really a great help...
  2. blocka
    blocka
    18
    Jul 7, 2010
    This line loads the byte into the register, you will need to wait until it finishes transmitting out the uart before continuing as the next instruction disables the tx, enables rx.
  3. sherazi
    sherazi
    91
    Mar 8, 2010
    would you just correct my code?
    Code:
    #include <avr/io.h>
    #include <util/delay.h>
    int main (void)
       char ReceivedByte=0;
    	PORTC &=0xDF;// Make PC5 low
     	PORTC |=0x20;// Make PC5 high
          UDR0 = ReceivedByte ; // Echo back the received byte back to the computer
    	  ????????????? what should be here???
  4. blocka
    blocka
    18
    Jul 7, 2010
    Sorry i don't know which micro you are using but you need to look at the UART registers and there will be a bit that you need to check to see the Transmitter is idle and do a while loop like your other while loops. It possibly is a bit in the UCSROA register like the other status bits you have.
  5. sherazi
    sherazi
    91
    Mar 8, 2010
    now another request plz can someone share a circuit /schematic for rs485 using max485 keeping in mind distances upto 70 meters
    should this circuit work if r39,r36 & r40 are not used? also the zener and the led section also be removed [​IMG]
