RS232 addressing
Discussion in 'Microcontrollers, Programming and IoT' started by pmciprian, Sep 3, 2011.
  1. pmciprian
    pmciprian
    Sep 3, 2011
    Hello,
    I would like to know if anyone could get me started on a project for designing a circuit that will check the first byte sent over RS232 and if it matches a set of dip switches, it will passthrough the rest of the RS232 signal to another controller, otherwise it will passthrough nothing. Any advice would be greatly appreciated.
    Phil
  2. sid2286
    sid2286
    102
    Aug 24, 2011
    Are your dip switches connected to certain port?
    1.read the port status first.
    2. Check the incomming byte from RS-232
    using if condition or a while
    eg
    if(port_status==Incomming_byte)
    pass to other controller;
    else
    do nothing;
  3. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    As RS232 is not intended to be chained you need to work on hardware side too.
    here under a link to such an application:
    http://www.weedtech.com/an100.pdf
    having a µC with 2 UARTS (like the ATMEGA644P) will also be a solution
    cheers,
    Olivier
