Rpm Problem turntable Sony PS 333 direct drive
Discussion in 'Audio' started by Sploof, Nov 21, 2018.
  1. Sploof
    Sploof
    5
    Nov 21, 2018
    Hello,
    I had my sony ps 333 direct drive for years and all of a suddend the pitch started to be very low. It’s neither 45 RPM or 33 RPM. Its got a wheel where I could adjust it, but it only skips from super fast to very slow.
    I don’t really know what to do about this. I’m greatfull for every response.
    Thank you in advance
  2. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    Could be a simple break in the circuitry around the actual speed control itself.
    A full technical manual is available for download https://elektrotanya.com/sony_ps-333_turntable.pdf/download.html which gives all the details necessary to take the unit apart.
    Page 10 shows the small PCB carrier that has the speed control soldered to it and you need to either make very close inspection of the joints or post close-up, in-focus picture that we can inspect for you.
    Sploof, darren adcock and Harald Kapp like this.
  3. Sploof
    Sploof
    5
    Nov 21, 2018
    Thank you so much and sorry for the late reply. I opened it up and see RV1 and RV2. For some reason I can’t upload pictures of them.
  4. Sploof
    Sploof
    5
    Nov 21, 2018
    So I tried playing around with the RV 1 and listening if the pitch is better, but now the rpm is pretty much equivalent to the speed of light.
    I can’t slow it down by any means. I think I broke the pitch controll, while playing around with the RV and now it’s set to the highest rpm possible. :(
  5. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    They are probably too large. Resize them to 800x600 and try again.
    Sploof likes this.
  6. Sploof
    Sploof
    5
    Nov 21, 2018
    Thanks. Here are pics of the two RVs. Tell me if you need another angle or a pic of a diffrent part.
    I still can´t regulate the pitch over the RVs. My thinking is that the speed control nob is broken and is constantly on full throttle. IMG_8667-min.JPG IMG_8668-min.JPG IMG_8669-min.JPG
  7. Bluejets
    Bluejets
    3,764
    781
    Oct 5, 2014
    Both look to be in rather poor condition and probably need to be replaced.
    Sploof likes this.
  8. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    I'd try noting the current position of the wiper (look at the orientation of the 'slot' in the metal top part of the preset potentiometers) and give them a twist left and right to 'wipe' the tracks and potentially restore contact - assuming it's been lost due to dirt/corrosion. Set them back to their original positions though. Use the appropriate small flat-bladed screwdriver and do this CAREFULLY so as not to damage them.
    Most of them look to be set at their mid-point already so movement either side of this is always possible.
    Show the actual speed control potentiometer too (as shown on page 10) - we need to see a close-up of the soldered connections to establish that one end hasn't broken loose.
    Sploof likes this.
  9. Sploof
    Sploof
    5
    Nov 21, 2018
    I tried screwing it all the way left, then right and into an neutral position again to clean the contacts, but it still is way too fast. Interesting is though, that there is still an noticeable diffrence between 33 and 45 RPM. So its not going as fast as it can.
    These are Pictures of the speed controll potentiometer (i cant unscrew it and take it out, because its glued into the frame)
    It looks a bit wavey, like heatdamage and I also noticed a tiny crack at the sony print between the N and the Y.
  10. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    Temporarily disconnect the red and orange wires from the control pot circuit board and measure the resistance between all three points (either end of the pot track to the wiper). Let us know what the results are.
  11. Ylli
    Ylli
    268
    70
    Jun 19, 2018
    Do as kellys_eye say, but I'm going to suggest a different path.
    Please measure the DC voltage on each of the three pins of Q4 and post them.
Similar Threads
Loading...
