rotary switch help!!
Discussion in 'General Electronics Discussion' started by paraflyer123, Mar 9, 2011.
  1. paraflyer123
    paraflyer123
    Mar 9, 2011
    hi
    new to this forum so hope somebody can help me! i have tried to find including alibaba .com a simple on/off rotary switch with to connectors on the back but it seems they are not made-does anyone know where i can get them? attached is the general spec i need
    thanks
  2. davenn
    davenn Moderator
    13,675
    1,892
  3. paraflyer123
    paraflyer123
    Mar 9, 2011
    thanks for that dave-i have contacted them-i tried google but couldnt get the results i needed
    tony
  4. (*steve*)
    25,419
    2,790
    Following davenn's advice to you, I followed that link.
    Then I typed in "rotary switch" and pressed enter.
    Then I was given a list of possible categories. I clicked on "rotary" in the "switches" category.
    The parametric display was shown.
    First I selected No of positions = 2, and clicked on Apply filters
    Then I clicked on Number of decks = 1 and clicked Apply filters. (I'm not sure exactly what decks are, but I assume it means layers of contacts, and you need only 1)
    I then select SPDT (because there's no SPST)
    I get a list of switches.
    Look at them one by one, reading the datasheets (which will have dimensions). There are a number of very close matches for what you want I think.
    Remember that if the shaft is too long you can cut it.
    SPDT will have 3 connections on the bottom. You can ignore the one you don't need.
