Thank you so much for your replies to date.
I bought a dozen PIC16F690's because I like their size so I don't wish to change the PIC. I use my circular saw to cut breadboards into 3 sections and this PIC with 20 pins fits nicely and has ADC.
All 8 C register pins are used to drive the 7 segment display. Pin 17 or RA2 is used to detect ADC. Whatever this analogue value is, is printed out on the 7 segment display which flashes out the value with a pause between numbers.
At various times I have measured battery voltage, temperature, IR brightness, light brightness (photoresistor CdS), soil conductivity (electrolysis), variable resistance. Trouble is that each time one does a project it takes time to calibrate each sensor to say, get the right temperature or voltage. Just as I now have a standardised PIC setup, I was thinking of a module with various sensors which have all been pre-calibrated. This way I just do it once and for all. I thought it would be nice to have this all set up, then one just clicks the rotary switch to whatever you want to measure (like a multimeter) and it spits out temp, or voltage or lux, or IR brightness etc. Currently I am using a thermistor, which can be seen on the right of the photo.
The A and B registers give me 6 potential analogue inputs, but I would still then have to choose which one to display. I suppose I could attach a press switch which toggles through each sensor in turn, but that is 7 more connectors to 7 more pins which makes it more "busy". Ideally I would like just 2 wires to the sensor board - but then I would have liked to have been born Brad Pitt, but that's not possible either.
