Jim Thompson
Can ROHS components be soldered with Pb-Sn solder?
...Jim Thompson
...Jim Thompson
Jim said:Can ROHS components be soldered with Pb-Sn solder?
...Jim Thompson
Chuck Harris said:Well, yes and no.
The tin in the RoHS parts dilutes the tin-lead solder, and makes
it a funny alloy that usually looks frosty when it cools. I would
suggest using 60-40, as opposed to 63-37 solder. The resulting alloy
sure looks better. As the tin heats up on the part, it wrinkles
and looks really nasty where it is exposed to oxygen.
All that aside, once you get a decent looking joint with tin-lead
solder, on RoHS parts, things are great.
When you start working with lead free solder, you will notice that
"good" joints look like cold solder joints with normal solder.
Also, in storage, RoHS parts oxidize and that prevents them from
taking solder, so be wary of older stock parts.
The electronics industry is going to be hurt really bad by this
stupid diversion into giving the euronation that warm and fuzzy
feeling of being lead-free. Their time and efforts would be better
spent ridding themselves of lead plumbing. Lead, the "plumb" in
plumbing.
-Chuck Harris
Well, yes and no.
plumbing.
-Chuck Harris
ian said:What date is set for RoHS? I just bought a reel of lead-tin solder, if the
cut off date is still to arrive I can wait till it passes and go repeat the
order and see what happens!
Well, yes and no.
plumbing.
-Chuck Harris
Philipp Klaus Krause said:Lead-tin solder will be available for a long time: It's still allowed
for repairing legacy equipment and for personal (creating devices you
won't sell) use.
The date for RoHS is in one week.
Philipp
...Jim Thompson
won't sell) use.
Philipp
Jim Thompson said:I like that term "euronation" ;-)
Philipp said:Lead-tin solder will be available for a long time: It's still allowed
won't sell) use.
plumbing.
Absolutely!Jim said:Can ROHS components be soldered with Pb-Sn solder?
...Jim Thompson
What LEAD you to this question?Slurp said:I have original leaded lights in my cottage which are in need of repair.
Will I have to get hold of some lead free lead to re-lead them?
Will I have to advertise my cottage when I sell it as having lead free
leaded lights or partially lead free releaded lead free lights or what???
Slurp
Richard said:...
OTOH, their collective madness may actually be caused by the led
leaching out of solder joints in discarded electronic
stuff in their landfills. Maybe they really need Lead-Free?
Richard Crowley said:...
the led leaching out of solder joints in discarded electronic
nospam said:Wouldn't you expect that a child who goes round chewing 40 year old paint
work or licking exhaust emissions from the pavements
The solder used in electronics is only 37 to 40% lead. Metallic lead
is not
overly prone to becoming a water soluble salt. Lead entombed in a
properly
designed landfill tends to stay entombed. It doesn't show up to any
great
extend in the leachate.
Car batteries are a far better vector for lead to enter the
environment, than
electronics... One has only to look at the quantity of lead in a
battery, and
the ubiquity of lead acid batteries to figure this out.
