Rocker switch ID ?
Discussion in 'Electronic Components' started by Fred Bartoli, Aug 21, 2005.
  1. Fred Bartoli
    Fred Bartoli Guest
    Hi all,
    I've an AMREL power supply that have its rocker switch gone.
    I've tried email them twice to have either the switch ref or a replacement
    part but they never bothered to answer (despite their claim to answer every
    email within 24h) :-((
    Unfortunately the switch (DPST) is not of some standard size I could fit in
    and I'm stuck with it.
    The mounting hole size is 1" high x 1.1" wide and the lateral "retaining
    springs" are not on the usual side.
    The switch has a stylized CX MD50 mark on it but it didn't help.
    Can anyone recognize it (switch or logo) or give hint on the manufacturer?
    (see pics on abse)
    Many thanks in advance.
  2. Looks more like "LCX", but that doesn't ring any bells. There are lots
    of offshore makers of these things, and I don't see any safety-agency
    approval marks on this particular one, so perhaps it's a domestic
    China maker. Some of them are not very impressive quality- overheated
    molded parts that are brittle is one problem I've seen. Best to spring
    for the ones that have at least passed UL/CSA (and verify such
    claims).
    Alco PRDDA1-16F-BB000 should fit if the springs have enough space to
    get in the other way.
    Best regards,
    Spehro Pefhany
  3. And while you're at it, you can include a light in the new switch to
    indicate on/off. Unless of course the PS already has its own lamp or
    LED. Never heard of Amrel.
  4. Fred Bartoli
    Fred Bartoli Guest
    Thanks Sphero,
    I missed that one when looking digikey.
    Yes, the logo is CX, with a double C (the unfortunate shade made it look
    like an L). Ah, maybe the logo is CCX. I'll have a look.
    The switch carries the usual approvals for worldwide selling. I just thought
    it was obvious and didn't included the other side pic. Sorry.
    It seems the Alco switch will mount OK into the front panel cut.
    Unfortunately the rocking axis will not match the front panel marking but
    I'll use it if I don't find a better one.
    Watson,
    have a look at www.amrel.com
    I bought the PS used on ebay a few years back and had a bad surprise with it
    (one of my first buying). It was supposed to be a working one, but one of
    the bypass cap had a pb, has been simply removed (yes) and some burned
    tracks have been 'repaired' with... solder braid. One output power
    transistor has been, well..., hum, changed for an 'equivalent'.
    Due to shipping costs, I had better to keep it and repair it. So I reverse
    enginneered it: the schematics is... kind of original, but it works, and the
    PCB layout is totally childish and in no way coherent with a professional
    design of the end of 80's. Somewhat disappointing and surely not an HP grade
    product. I hope for them (and their customers) they've improved their
    quality.
