Robot servos shaking when registering to a network via radio
StevenKey
Nov 20, 2014
Nov 20, 2014
Hello all,after some weeks trying to develop some working code & hardware, I come here as I haven't found a solution for my problem.
I've a robot which has a mega 2560, but the radio is an EFCom Pro V1.0.
I tried to solve this by very different ways, and when finally solved it, it comes again, without knowing why.
My problem is just that the two servos which are connected to the power supply I home made, are shaking when I power on the module and it registers to network.
Seems like is powering off the servos and they come on again and again... and I don't know why nor how is doing this. (this is just a theory).
The thing is I have the code here, and the schematic of my power supply. My servos are both SG90 TowerPro 9g. And nothing else I think is relevant.
I say that coded a software in pure C for Freaduino Pro Mini 5V, but when I solved the problem by making very fast PWM and implementing my own software serial, I got the problem again, so I disconnected the power supply and put wired it like when solved it, and my servos were still shaking... I went very depressed, I've coded a lot of code with this project, and I don't mind because I love it, but really, I think I've made a lot of work on this. So, please, what can be making my servos to shake like being under electroshock, when I power on the module and Call Ready is received? I only issue checking commands as AT+CREG? and AT+CGATT, and when both ready or okay, then I enter into a loop of simple AT commands. And the servos stop shaking the whole time, then after some seconds of running, they start to shake a bit, like if the signal goes down and the TX power is higher...
really, I don't know which problem is with my power supply, but I tried to power on the servo with an external battery and the same.
Both servos are new. I just received the second 2 days ago, and tested yesterday night with same results...
davenn
14,263
14,263
hi there Steven
Welcome to Electronics Point :)
I cannot help you with your specific problem ... just wanted to greet and welcome you
We have several guys on the forum that quite knowledgeable with micros
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
What happens if you disconnect the servo from the microcontroller?
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
What power supply are you using and where do you take the power for the servos from, what servos are you using? Can you show us a schematic? What timings are you using for the servo PWM.
Adam
Frenoy Osburn
Nov 20, 2014
64
Nov 20, 2014
64
Apart from what Adam mentioned, could you also tell us how are you controlling the PWM output? Does the servo still "oscillate" when you give a fixed PWM value?
If you happen to have access to an oscilloscope, I would probe this signal and verify the same to rule out any issues with the PWM module you have going.
7,682
7,682
It sounds to me like the PWM signal is not continuing while you are doing the communication.
