Rising or falling edge.....
Discussion in 'Electronic Design' started by [email protected], Dec 19, 2008.
  1. Guest
    Which would you use for pulse detection/counting?
  2. MooseFET
    MooseFET Guest
    It depends on a lot. In at least one case, I used both edges.
  3. Guest
    Assume noise is already filtered and you're just counting pulses with
    a MCU where just changing a bit or two determines detection on rising
    or falling.
  4. neon
    neon
    1,325
    Oct 21, 2006
    DEFENETLY RISE TIME if it is active fall time is usualy passive and therefore longer in time.
  5. TTman
    TTman Guest
    both for detecting, neg for counting.In a micro, you would use (preferably)
    interrupts.
  6. Guest
    So if noise is out of the picture and you have control over and set
    the inactive steady-state of the pulse source to Lo, then it's only a
    falling edge ISR that one needs to concentrate on?
  7. Rich Webb
    Rich Webb Guest
    Ding ding ding ding ding ... We have a winner! :)
  8. TTman
    TTman Guest
    Ha ha, if everything goes belly up, who cares if a pulse is missed, unless
    you're counting gold bars :)
    Happy Xmas you lot .
  9. Jamie
    Jamie Guest
    Hmm, sounds good for ECL, but how about CCL ?
    http://webpages.charter.net/jamie_5"
  10. Jamie
    Jamie Guest
    Depends on the device that is doing the pulsing?
    It's logical to use the level the device generates
    when its TRUE/ON
    For some, the raising edge how ever, this leads to
    problems where the devices must insure it does not over
    drive the unit that is receiving the pulse.
    If you use an open collector type device for example, you
    can then have the monitoring device use it's own pull up or
    what ever voltage it requires and the pulsing device won't
    care until you breach it's limits of course.
    So, with that, I would say a falling edge using an open collector
    pulser would be the ticket. And even if a totem pole/Line driver
    output device was connected for some reason, it could thus use the
    receiver device supply voltage to insure it does not get over driven.
    And with that, you still can use falling edge..
    In the case of a pulsing device that has NOT outputs with
    open-collector, you then are faced with PNP outputs on the NOT's in
    many cases and NPN on the non-NOT's
    NOT's are high side, others are low side open-collector.
    In the case of the NOT's, you would have to supply a pull down
    R. unless you design your receiver device to work with NOT/PNP sensors.
    etc..
  11. Jasen Betts
    Jasen Betts Guest
    In an MCU you would use a hardware counter and interrupts only to
    handle counter overflows
  12. Jasen Betts
    Jasen Betts Guest
    it depends if you're more interested in the beginning of the
    event or the completion of the event.
