ribbon code
priit
Aug 11, 2016
6
Aug 11, 2016
6
Assuming that this is inductance with ferromagnetic core, how many mH it is ?
Produced 10 years ago.
priit
Aug 11, 2016
6
Aug 11, 2016
6
I do not want to say at the moment anything about my opinion. If they are other offers, it would be interesting.
I have no room for mistakes.
I was happy to measure Ω, before it got broken. DC resistance was 12Ω
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
The value is correct, but other options are DC current , Frequency - SRF and of course DCR.
If this is critical, we need to know circuit parameters & application
The red coating was added?
priit
Aug 11, 2016
6
Aug 11, 2016
6
You are welcome. Application is robot loader controller part (i/o) card.
Supply voltage 24Vdc, signals i/0 24Vdc.
Red coating-warranty ? No, this is not an issue.
As I do not have wiring diagram of this card, I do not want burn down something and wish to get everything running ASAP
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
next question is why did it fail? why was it suspect?
THis choke reduces the current surge charging up the 1000 uF cap to some voltage when switched on. The cap ESR may be lower than the choke DCR of 12 Ohms. thus the current di/dt =V/L where dt is the charge up time.
This is a basic Current spike decoupling choke where the surge current is limited by V/(R_total)
Assuming 20V to a 25V cap worst case, and R_total = 15Ω, I max = 2A for a few milliseconds then expected load should be 200mA for decent load regulation . I would choose a higher current rating choke than 200mA as a guestimate as the choke simply acts as a resistor with low L when saturated.
Even a 12 Ω power resistor might work, but the L reduces pulse ripple current to source supply to triangle waves.
Risk low. 10% tolerance ok if voltage applied is lower, then lower current rating is Ok.
Does this drive small motors? then measure DCR of motors and consider higher. current rating.
priit
Aug 11, 2016
6
Aug 11, 2016
6
Good question. Burnt inductance was visible fault when I opened box. Why I opened the box ? Because ultrasonic proximity sensor what was one of the inputs in this card, sometimes malfunctioned.Sometimes not. Sensor seemed to be ok, so my next step was to go further. Actually original one was this:
I had a spare card, but during soldering one leg of inductance brokened.
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
alec's part seems to be the closest match
To reduce self heating, I would use 500 uH rated for 240mA with DCR of 7Ω which is two of Alec's chokes in parallel . These are like 1/4W resistors which would burn out with 1/2W.
A lower DCR of 3Ω would work but increase dissipation power in 1000uF cap with ripple current.
Often designs like this shunt parallel caps and chokes for redundancy any reliability. Hi Rel designs try to increase the circuit R to limit charge currents to caps.
These days ICL's are used to perform this better, like a Polyfuse but with NTC instead of PTC.
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
priit
Aug 11, 2016
6
Aug 11, 2016
6
Experimentation with measuring tools is tricky, because card is installed in tight rack.But we will see.
Anyway, thanks and greetings to you Sunnysky to Canada, I will order some more inductances from Farnell as they dont cost a lot and see what happens. Resistor assortment is acceptable here in local shop.
Now I have something to think.
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
twisted pair out from current sense 10Ω R can use two probes in differential mode.
single end to monitor Vdc.
