Ribbon Cable Too Small to
Discussion in 'General Electronics Discussion' started by consec, Oct 8, 2012.
  1. consec
    consec
    3
    Oct 8, 2012
    Ribbon Cable Too Small to separate wires
    Hi Guys, I've got a problem. I'm trying to extend a ribbon cable for a cell phone camera, but the cable is far to small to separate the wires sufficiently to breadboard or solder. I'm looking for any ideas on how I might connect this component with a longer cable. Picture attached...
    Thanks for any help you can give.
  2. (*steve*)
    25,499
    2,839
    I'm not even sure what I'm looking at or where the cable connects.
  3. consec
    consec
    3
    Oct 8, 2012
    Sorry, it's so small I can't really get a good picture with my crappy camera. I'm talking about the flexible plastic kind of ribbon cable. The orange piece in the middle is the ribbon cable in this case. Hopefully that helps to clear things up a bit.
  4. (*steve*)
    25,499
    2,839
    OK, so it;s a short section of ribbon cable (possibly flexible PCB) between the two small parts?
  5. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    That is my guess, and without A LOT of patience trying to jumper wire all those flexible pcb connections with traditional wires your best bet is to have a custom flexible PCB cable made that fans out to a more solder friendly configuration, sadly this is VERY costly for a one off... My advise is to seek another camera that is more suitable to tinkering, ore get out the magnifier lens and get a plan of attack done with wrapping wire jumpers...
  6. consec
    consec
    3
    Oct 8, 2012
    Yeah, that's kind of what I could think of as well. I'm certain I don't have the steady hands or patience to try to wire it.
    Even finding another camera is a bit hard, as all the Android phones I've seen use the same style cameras, although some have slightly longer ribbon cables which would make things a bit easier.
