Mike Hainsworth
- Oct 9, 2017
- 1
- Joined
- Oct 9, 2017
- Messages
- 1
Simply put I wish to trick my car's ECU into thinking the turbo boost has not reached a certain level.
12 volts is supplied to a pressure switch with zero being fed to the ECU when there is no boost pressure.
As the pressure rises the switch feeds out a corresponding voltage up to 5 volts when maximum pressure is reached.
I have increased my turbo pressure (this is fine on a diesel as it will not cause a lean mixture) and it now causes the ECU to cut fuel as it recognises an over boost situation.
What can I do to limit the maximum voltage output to say about 4.5 volts?
I need the signal to be somewhere near correct just muted, i.e. as the pressure rises so does the voltage even though it is slightly lower than original.
Any help (and preferably simple) as this is for simple person and the fitting is in the engine bay of a 4X4.
Cheers
Mike
Cheers
Mike
