RGB leds color changing help...
Discussion in 'LEDs and Optoelectronics' started by martin the warrior, Aug 18, 2016.
  1. Harald Kapp
    9,892
    2,096
    Right. And can then be pwm controlled to achieve the desired hue and brightness.
  2. Hellmut1956
    Hellmut1956
    53
    3
    Aug 11, 2014
    Let me repeat it. Thousand thx for the great advice. I am right now searching for a source to buy a 2 pole/ 4 pin switch that has a 14 mm x 15 mm size. So far I have only found some that were too long to fit as a replacement for the current build in switches. I am also quite interesting to have them lighted with preferable green or red color and have the "I" and "0" marking.
