- Joined
- Jan 21, 2010
- Messages
- 25,510
In your response, you added the word "just" which clarifies what you mean.
Perhaps you need to read what I wrote and not what you quoted.
In any case this is pointless because it's not helping solidshark.
solidshark91493 said:(*steve*) said:solidshark91493 said:Heres the spec sheet for my led's
http://i1248.photobucket.com/albums/hh496/solidshark91493/Untitled-1.png
That says 20ma
So I have to limit the lights to the individual voltage levels correct? .-. so Ill need 18 resistors,
And ok, so 7.5 amp wall wart. does amp equal watt? Im sure I could look it up but Ill ask anyway. They sell a 6 watt one, and a 15 watt one. (Smallest ones) Maybe I could get a different one somewhere else that would be better?
It would be better to ask this in the thread. Also you need to tell me how many LEDs you are planning on using.
The short answer is that a 12V 7.5A power supply is a 90W power supply (watts are volts x amps)
a 90 watt supply? thats WAY too much. I can power 6 rgb leds with my arduino off a 9 volt battery.. :|
I cant imagine I would need more than 15 watt.. But I guess I could still be wrong.
Im using 6 of these.
http://www.ebay.com/itm/100pcs-x-5m...Common-Anode-LED-Red-Green-Blue-/261083069774
I have 600 of them. But I only wanted to use 6 since what im putting them in isnt that large. I could go to 9 I suppose.
I only did that to try and get an answer further. ok then.You have 6 leds. At 20mA max for each R, G, and B, that's 0.06A * 6 = 0.36A.
From a 12V power supply that's 0.36 * 12 = 4.3W.
Tiny 12V power supplies are a dime a dozen. You'll probably find a 12V 1A power supply very easily.
Connect them up as you suggested:
Do you know how to calculate the resistor values?
And please don't send me private messages for things like this, ask them in the thread.
Yep, anything from 360mA up to whatever. 1A will allow you to expand to 16 LEDs if you need to.12v 1A power supply. Got it.
Easy The theory stuff is here:https://www.electronicspoint.com/got-question-driving-leds-t256849.htmlresistor values? No idea, I had a calculator but Idk where it was from.
Ok. Ill give it a try. and report back, it'll be a few days though.Yep, that's right.
I'd probably use 470 ohm resistors for all three. That way there's less chance of making an error.
My advice is to wire us a single LED to the controller first. This will ensure you have everything wired up right. If you make a mistake you'll only destroy 1 LED
That's excellent news.
If that really is a 5V power supply (have you measured it) then the LEDs are going to be running at a lower current. If they're bright enough that's fine.
It is possible that the power supply is 12V as the arduino has a voltage regulator which steps the voltage down to 5V, although running them at 12V is typically a little higher than typical -- 9V is more common. And of course, you can run them from 5V.
Because there's a resistor for each LED element, they will not get hotter as you add LEDs. Your power supply might though.. (but that was the point of making sure the power supply was of a suitable capacity.
In this application I can see no reason not to heatshrink the resistors. It may help prevent shorts, and it depends on how you're wiring them as to whether this is likely or not.
Yes, the heatshrink will reduce the cooling to the resistors, but in this case they require so little it should be fine. (at 20mA they would dissipate 0.2W, and as long as these are 1/2W resistors or greater, heatshrinking will be fine)
1/4 w is pushing it for covering in heatshrink. However it does depend on whether the LEDs will be a t full brightness and for how long. If your controller uses PWM and keeps the average brightness low, it may not be too much of an issue. Also the leads of the resistor will provide some heatsinking.
If they remain cool to the touch when in operation from the power supply you indent to use, then they should also be fine to heatshrink.
This may be a candidate for a new thread, but let's continue here for a bit.
Essentially, if you've done a 1 colour cube, a three colour cube is exactly the same except instead of wiring one set of anodes, you need to do three.
It's likely to end up as a much more busy set of wires.
There must be a youtube video of someone showing you how to do it -- surely!
How about this?
