RF Tension Follower
Discussion in 'General Electronics' started by David Moreno, Jun 6, 2004.
  1. David Moreno
    David Moreno Guest
    Hi All !
    I'm trying to do a simple tension follower for frecuency
    up to 100MHz. Actually I'm using a BF998 with a R=1k attached
    to the source, but i'm observing that the tension output not
    resembles very well the tension input (about a 1/3 attenuation)
    , Is there any simple circuit for doing an analog tension follower (high
    input impedance) that works at high frecuencies ?
    Thanks a lot !
  2. jerrykrinock
    jerrykrinock Guest
    Note: For USA engineers, translate "tension" to "voltage".
    Also, I believe the specific circuit you are referring to is an
    "emitter follower".
    1K ohms is a little high for 100 MHz. Try 330 ohms and see if it gets
    better.
  3. David Moreno
    David Moreno Guest
    Ops!, Sorry =D
    That's right, an emitter followe is also refered as voltage follower
    and common colector circuits.
    Yep, thanks ! =D
