RF gropund plane layout
Discussion in 'Misc Electronics' started by JB, Jul 30, 2003.
  1. JB
    JB Guest
    May somebody provide me with any theoretical-practical application note
    (articles, web pages ...) regarding RF ground planes layout (up to 1.2 GHz)?
    I certainly know about the characteristic PCB layout guidelines. A
    continuous ground plane on the back side of a printed circuit board as an
    ideal arrangement, the RF signal traces should be well terminated and kept
    short, careful decoupling of the power supplies, etc
    Even though I am confused about the topside ground planes requirement and
    disposition. I believe for sure that a number of different strategies could
    be adopted. That there is not a unique answer for the best. In my design I
    am considering three synthesizers involving a couple of mixers and filters.
    I have observed in some designs a different disposition of topside ground
    planes. Off course these grounds should be connected to the bottom side
    ground using plated through holes.
    In some cases these topside planes looked as big as possible. Getting almost
    "indiscreetly" all the given leads under the common ground on that plane.
    At the same time I have seen other layouts where the topside ground planes
    configured little islands. On these ground islands the leads of several
    components of particular functional network were placed
    I believe that the last strategy considering as many vias as possible could
    be really convenient .Is this correct?
    I do not have at this moment any simulation tool to test a given layout
    configuration.
    I would sincerely appreciate any hint.
    JB
