D
I am using a small SMT OSC module at 100 MHz that has good harmonics
to ~400 MHz to drive several sources on a board I have designed. I
need the output to be capable of driving a couple of 50 ohm loads to 0
dB. I cant find anything that will take a 3.3V CMOS CLK input that
can drive a pair of outputs into a 50 ohm load that will preserve the
harmonics fairly well. Ideally, I was looking for a single IC that
could do this, even if it was one channel... I could use two of
them. Any solution has to have a minimum of parts and be very cost
effective, in the dollars range. Any help would be great! By the
way, I can find plenty of LVDS differential drivers that can do the
job nicely into 50 ohms, but I don't know how to "single end" a
differential output without a transformer that I'm not allowed to even
suggest, and most of them require a differential drive, which I do not
have.
Many thanks!
have.
Many thanks!
