RF Circuit Battery Efficiency
Discussion in 'Radio and Wireless' started by mcasey, Jul 23, 2017.
  1. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    You can still do that with MOSFETS - look up the 'h-bridge'.
  2. (*steve*)
    25,361
    2,756
    Sure, it's an H bridge. What is its quiescent current? Can you do better?
  3. mcasey
    mcasey
    64
    Jul 9, 2016
    I bought a new switch to replace the LH1505 to try out. I CAN'T figure out why the COM & NO pins connect when I apply power to the either/or. It doesn't matter what I do with the IN (digital control). What am I doing wrong?
    http://www.ti.com/lit/ds/symlink/ts12a44514.pdf
  4. mcasey
    mcasey
    64
    Jul 9, 2016
    Got it! No digital controls can be floating. :)
  5. mcasey
    mcasey
    64
    Jul 9, 2016
    So I bought (what I think is) a more efficient regulator. However, I can't figure out how to wire it to get 3.3 volts. I do not have an inductor; is it necessary? Input is 5 volts. Please help.
    http://www.ti.com/lit/ds/slvsbk5/slvsbk5.pdf
  6. BobK
    7,680
    1,685
    Uh, yes. It is a switch mode regulator and the inductor is a critical part of the circuit.
    It is a fixed regulator, wire it exactly as in the datasheet, and you will get 3.3V.
  7. davenn
    davenn Moderator
    13,555
    1,853
    as Bob said wire it up per the data sheet. you are missing a bunch of components......
    2 resistors, 4 capacitors, a special diode, and the inductor ..... you MUST use all the correct parts and their values else it wont work
  8. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    Indeed - the datasheet tells you everything you need to know about using the device - how to connect it, how to calculate the component values etc.
    You can also 'cheat' and Google the device and search the 'image' results for examples of working circuits others have built. Indeed there are members on here who have attempted the very same:
    https://www.electronicspoint.com/threads/1st-buck-converter-design-help-advice.280000/
  9. (*steve*)
    25,361
    2,756
    Also be aware that building it on a breadboard may cause some problems.
    Fingers crossed.
  10. mcasey
    mcasey
    64
    Jul 9, 2016
    Ok, now I'm terrified! Although I'm sure this circuit seems very simple for most you on this forum, it's very difficult for me. Is there a more simple device (other than an inefficient linear regulator) that will get me down to 3.3 volts, or am I going to have to venture down this rabbit hole o_O ?
  11. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
  12. davenn
    davenn Moderator
    13,555
    1,853
    why didn't you continue with the one you posted a datasheet for in post #3 ? I said it looked good :)
    a much lower component count
  13. mcasey
    mcasey
    64
    Jul 9, 2016
    I haven't given up on it yet, but it is a little overwhelming for me. I need to order more components (like the inductor) and play around with it.
  14. mcasey
    mcasey
    64
    Jul 9, 2016
    I have decided to tackle this regulator, but need some help identifying the components needed... The items circled in GREEN are obvious to me. The items circled in RED have me confused.
    http://www.ti.com/lit/ds/symlink/tps5403.pdf
    My objective is to supply the RF receiver and decoder with 3.3 volts without the use of an inefficient linear regulator.
  15. (*steve*)
    25,361
    2,756
    Imagine you want 3.3V at 100mA. You have a battery which is currently reading as 6.6V.
    A linear regulator would have as it's input 6.6V at 100mA, and the excess energy would be expended as heat. This regulator would be 50% efficient at best. As the difference between the input and output voltage changes, the efficiency varies.
    A switch mode regulator in the same circumstance will input 50mA at 6.6V and output 3.3V at 100mA. It is (theoretically) 100% efficient.
    There switch mode regulator electrical energy in a magnetic field, then converted that magnetic field to electrical energy. This is done in such a way as to change the output voltage in a controlled manner.
    A linear regulator has an input current equal to the output current, dissipating the difference between the input and output voltage times the current as heat.
    The switch mode regulator has an input power equal to the output power, so if the output voltage is lower than the input voltage, the input current will be lower than the output current. The input current times the input voltage equals the output current times the output voltage.
    The inductor, diode, and capacitor in the top right corner of the circuit are three of the necessary four parts of a switch mode regulator (the 4th part is something which switches a current path on and off)
    Without those three components on the top right corner, you can't regulate voltage with this chip.
    Also remember that there are additional losses which I've not mentioned. Nothing is ever 100% efficient.
  16. davenn
    davenn Moderator
    13,555
    1,853
    the info is in the datasheet
    here's one example from it for calculating the inductor value ....
    continued on pages 10 and 11
    and following that is info on the capacitor values
  17. BobK
    7,680
    1,685
    On average.
    The typical buck converter topology has all the output current coming from the source during the on phase and none during the off phase. So the source would be outputting 100mA when the switch is on and 0 when the switch is off, for an average of 50mA.
  18. mcasey
    mcasey
    64
    Jul 9, 2016
    Thank you for this explanation. It clarifies the main difference between the linear and switch mode regulators. Unfortunately (for me :(), it doesn't clarify how to solve the equations listed on the datasheet.
  19. mcasey
    mcasey
    64
    Jul 9, 2016
    I'm sure the datasheet explains in detail, how to calculate the inductor and all capacitor values. However, I do not have the skills required to decipher these formulas. I have no idea how to solve these formulas:
    Furthermore,
    I do not know what type of diode to buy:
    I do not even have a basic understanding electronics. I just know my battery only lasts 26 days, and I want it to last longer, AS LONG AS POSSIBLE. I certainly appreciate all of the selfless help I have received on this forum, but I don't know what I don't know :confused:.
  20. mcasey
    mcasey
    64
    Jul 9, 2016
Similar Threads
Loading...
