Hi Joerg,
There is one TV jack. If the TV needs to be in another corner we'd just
run a longer cable to it. After all, it's only for the duration of a
sickness that might possibly strike some day.
Different perspectives. A neighbor was bedridden for several
years before just passing away. Another friend just diagnosed
with ALS. I.e., it's not uncommon for people to spend considerable
time "trapped" in a room.
Plus, a future owner would probably have kids and they would want
media access in those rooms.
"Wire is cheap" :>
Both have TV jacks. The back porch also has CAT-5 but normally unplugged
for security reasons.
I just change the routing tables to prevent them from going anywhere.
You must have built the house from scratch. There would be no way to get
CAT-5 to all those places here.
We re-routed the HVAC supply ducts. At the time, that gave us
easy access to many of the "interior" walls in the house. Birdboards
give us (continued) access to one of the exterior walls. And, the
"end" birdboards give us access to two of the other exterior walls.
In two places, I had to cut small holes in the ceiling to get the drop
*down* into the wall. But, doing so carefully make these easy to
patch.
The drops for the front porch are currently tucked up in the ceiling
*by* the front porch -- waiting for me to get a chance to remove that
paneling and stucco the porch. (No rush for those drops since we
couldnt leave anything *out* (TV, etc.) on that porch as it isn't
"secure".)
The real AC is never on anymore because we have an evap cooler now. The
We stopped using the cooler a few years ago. *I* prefer the moist
air (at least during the dry part of Summer) but I only get one "vote".
<frown>
But, the furnace and cooler are also controlled. I had hoped to
install motorized skylights so the cooler/ACbrrr tradeoff could be
dynamic and automated. But, with only that one vote... :>
time constant of that cooling is several hours, so we have a totally
revolutionary control concept: Walk over there, reach over, turn big
knob
For some other stuff we have several handheld RF remotes.
We used to have X10 for all that, with a central controller that can be
reached via any of the remotes. But the PLC part, comm standard, and the
hardware are all of sub-par quality so I ripped most of it out again.
Ive put reed switches on the floor to detect when the garage door is
fully closed. A long-throw opto-interrupter to detect fully open.
A sensor in the freezer to monitor temperature (and provisions to
monitor the compressor therein -- is it running "a lot" yet failing
to cool, adequately?). The same for the hot water heater (though
waiting to replace it before instrumenting that control).
Other things are much easier to accommodate. E.g., the doorbell.
There are "panic cords" in the bathrooms ("Help! I've fallen and I
can't get up!" :> ). I also ran controls for a motorized
projection screen in the living room (I consider the big TV's to
be an eyesore -- much nicer if the "screen" disappeared into
the ceiling).
Things like the thermostat and irrigation controller are a bit more
involved because they need to operate in the absence of "supervisory
control". I.e., if the automation server crashs, you don't want the
house to heat up *or* cool off extraordinarily. So, (part of) the
control loop has to reside in those "motes" -- not just the I/O's
(as is the case for the garage door, etc.)
I dropped my efforts to do that. It's impossible in an existing house
like this because there is no decent hardware at reasonable prices. Huge
untapped market, the big players simply don't get it.
Again, in our case, we took advantage of the opportunity to run wire
to all of those places. If we had an attic or basement, this would
have been much easier.
Once you have wire in place, it becomes relatively easy to script
many of these things:
for door in doors
if (doorbell[door]) {
announce_visitor();
locations = locate_occupants();
for l in locations
route_video(l, door);
Well, yeah, one would never mount those out in the rain. Although
there's cabinets if you had to. But the electrolytic in there would
likely croak soon.
The amplifier I have is intended to be outdoors. Presumably
taking into account the fact that it rains AND the sun shines on it.
One guy in this area had his roof starting to sag after that.
Yes but I wonder if they'd ever *notice*? This (partial) wall supports
(part of) a 25' 4x12 that carries the living room ceiling. It also
acts to psychologically isolate the living room from other arts of the
house (by breaking sight lines). *They* obviously decided the wanted
to *open* those sight lines -- without thinking about other reasons for
the wall's presence! :-/
[I was lucky to come across a set of prints for this house so know
where the footers are poured. "Gee, look at this footer in the center
of the house... right under this funky little wall..."]
