Ken Taylor said:
As Pete implied, your signal isn't the problem. When does the reception
deteriorate? Time of day dependant? Weather dependant?
Cheers.
Ken
Ah, sorry. I'm using a DVico USB model (they only have one) and FusionHDTV
version 3.00.00 I know that sounds a bit like an early release, but the
software's actually pretty good.
It gives a 'percentage rating' of signal strength, derived from what I don't
know. It doesn't seem to vary on weather, time of day etc but Channel 9 is
consistently poor; being hdtv it'll stutter and stop, and is generally
unwatchable. SBS (for example) is only a few 'percent' higher iin it's
rating, but is picture perfect.
So it seems that inadequate signal strength is the cause of the stuttering.
AFAIK all the stations transnit from the same location (Mt Tamborine, being
a big old extinct volcano in the area, good for putting transmission towers
on) so I don't know why it affects only Channel 9.
So, I was hoping that an RF amp would boost the signal strength enough to
make things work properly. I've seen various distribution amps / splitters
at Jaycar and DSE, but they seem like a bit of overkill; I'm only running
one TV, so just need an amp, I'm guessing.
Getting the landlord of the block of flats to alter whatever antenna
arrangment is in place isn't really an option. I've tried the unit with a
set of indooe UHF rabbit ears and get no signal at all.
I can handle a soldering iron, but know well enough that RF circuits would
be beyond my ability.
Sorry for not being more clear in the first place, thanks for the replies.
Rob
