whiterabbit
- Sep 14, 2013
- 90
- Joined
- Sep 14, 2013
- Messages
- 90
I can try the dual 6v batteries I used initially to test the EQ initially. Hopefully that will be enough to run this second test; if not, I'll just add one stage of inductors and capacitors and see if that helps.
I ordered 8 of each of the three parts you recommended.
I also recently ordered several kits: capacitors, inductors, and transistors. Nothing fancy, just wanted to have a stock supply on hand for immediate testing purposes for my upcoming projects.
I've been looking into high and low pass filters for a separate project... that's basically what the capacitors and inductors are used for, right? The plans I've seen for passive low pass filters often have inductors in them. And the high pass have been capacitors and resistors alone. Am I on the right path with this line of thought?
