C
[email protected]
I have a 2.5hp GE 13.1 amp motor that I'm using to build an air
compressor. It currently turns in the wrong direction and would be
very awkward to mount with this turn. It turns clockwise when looking
at the output shaft and I need counterclockwise.
There are two capacitors on the motor and what looks to be a
centrifugal switch. Based on what I've read it seems that I can
change
the direction of the motor by switching the leads of the starting
circuit. Unfortunately I cannot seem to find the end of the starter
circuit.
What I'm able to decipher from the wires is there a three wires going
in. Green goes to ground on the casing. The white joins with yellow,
which splits - one side goes through the centrifugal switch where it
comes out as black and goes through a philips black plastic enclosed
capacitor where it comes out as black and is routed somewhere
inaccessible near the stator (I think this is the starter cap); the
other side joins with a blue wire next to the stator, and then passes
through a steel enclosed capacitor where it comes out as orange and
is
routed somewhere inaccessible near the stator (I think this is the
run
cap).
The black wire joins to red and passes through a motor protection
device prior to being routed somewhere inaccessible near the stator.
The stator appears to be affixed into the motor housing and I do not
see how I can get it out to switch leads for reverse rotation.
Is it possible that all I have to do is swap the leads on each
capacitor to cause the current to flow through all the wires in the
opposite direction?
Any help would be appreciated. As you can see I am not and expert in
this field by any means.
Thanks.
change
circuit.
is
run
cap).
opposite direction?
Thanks.
