Tim Wescott said:
I can certainly see your point with the ones that are rated much above
10A -- not to mention 100A!
The real question is -- how much current does it take to make sure that
the diode is saturated with minority carriers, thus making the reverse
recovery time measurement representative of what will happen at rated
current?
What's even more bizarre, if they do that on the really big diodes
(>100A), capacitance will be so huge relative to the 1A reverse current
that they'll look even *slower*! Same as calling a schottky "4ns" or
something, which is based only on junction capacitance and test current.
Presumably, all junction diodes use approximately the same current density
(allowing for differences in voltage and speed), so they'll be fairly well
saturated at rated current. Somewhere up the knee, where they start
looking resistive (1~2V).
The diodes that provide a graph usually have parameters of If, dI/dt and
Tj, and end up in the 200ns range for something like dI/dt-snubbed hard
switching (like CCM buck/boost). It would be nice if they'd just use that
number to begin with.
Tim
