reverse polarity relay??
Discussion in 'General Electronics Discussion' started by OZEXPAT, May 5, 2013.
  1. OZEXPAT
    OZEXPAT
    3
    May 5, 2013
    I am not anything remotely close to an electronics expert and am seeking help
    I want to find a polarity reversing relay to control a linear actuator on a timer
    I found a wiring diagram on line
    [​IMG]
    It is described as a DPDT switch internally wired for polarity-reversal applications: only four rather than six wires are brought outside the switch housing
    where can I find something like this - i am unsure by descriptions if I am looking for the right thing
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    You have the description, it's a DPDT (Double Pole - Double Throw) switch or relay... You can find them all over the place, try Google, Ebay or your local/Internet electronic component store...
  3. OZEXPAT
    OZEXPAT
    3
    May 5, 2013
    I have seen DPDT but none set up internally for polarity switching. Can I do this outside the relay?
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Yes, the way you connect the wires produces the desired result...
  5. OZEXPAT
    OZEXPAT
    3
    May 5, 2013
    thank you.
    The comment that its set up internally threw me - I can do this!ou
    thank y
  6. (*steve*)
    25,477
    2,820
    May not be useful, but...
    In addition, you'll often see exactly the same wiring, but with each set of contacts on a different relay (i.e. two SPDT relays). This allows a motor to got forward, backward, or stop.
    Normally the relays are wired to that when neither is powered, the motor is off.
  7. Six_Shooter
    Six_Shooter
    98
    Nov 16, 2012
    As suggested two SPDT relays can be used.
    Look up the wiring used to control door lock actuators in a vehicle. You will notice that when done this way that only one actuator is energized at a time, due to the at rest polarity of the system.
