Jon Jerpbak
- Jul 24, 2015
- 3
- Joined
- Jul 24, 2015
- Messages
- 3
Using a light organ (Velleman MK114), I want a light to turn off to the music rather than turning on. This means the normal state of the light is on. I've tried using a NOT gate but the voltage coming out of the color organ is quite varied and the NOT gate is just on/off. I do not have access to an oscilloscope.
I'm looking for a device or circuit that will adjust the output voltage depending on the input voltage.
As an example:
Assume that the color organ out put voltage is anywhere between 0v and 9v.
If the input of this 'new' circuit is 0v, i want the output to be 9v.
If the input is 3v, i want the output to be 6v.
if the input is 9v, i want the output to be 0v.
I just need to be pointed in the right direction.
As an example:
