Rev Counter on Diesel Engine
Discussion in 'Boat Electronics' started by Brian Runyard, Nov 14, 2003.
  1. I'm in the process of replacing the old AQ110 petrol engine (negative earth)
    in my boat with a Perkins Diesel.
    Is it possible to retain my original Rev Counter (signal from contact
    breaker), but pickup the signal from the Alternator instead and recalibrate
    the instrument (I have an accurate hand held tacho to compare it with)?
    Regards,
    Brian
    http://homepage.ntlworld.com/brunyard.
    The Information contained in this E-Mail and any subsequent correspondence
    is private and is intended solely for the intended recipient(s).
    For those other than the recipient any disclosure, copying, distribution, or
    any action taken or omitted to be taken in reliance on such information is
    prohibited and may be unlawful.
  2. Larry
    I don't have the Perkins tach, so before parting with hard earned cash I
    wondered if I could modify what I've got.
    The engine is a Perkins Prima 78hp Turbo, out of a car so I've got to spend
    about £700 for the marinising kit.
    Regards,
    Brian
  3. brian clode
    brian clode Guest
    asap supplies in the uk sell Faria rev counters that use alternator
    sensing,( I have two on twin diesels)
    www.asap-supplies.com
    good luck Brian
  4. Larry
    The engine plus a second for spares only cost 60UKP.
    I experimented at the weekend, and have solved my problem.
    1. Built a circuit that uses an optical sensor
    2. Removed the circuit board from inside the tacho, so it's just a moving
    coil meter.
    3. Put 2 white blobs on the flywheel.
    4. Calibrated the circuit.
    Works wonderful.
    Regards,
    Brian
  5. BruceM
    BruceM Guest
    Yeah, until it gets oil or grease or something on it!
    BruceM
